2001 1.0 Yaris radiator replacement
VosperD
Is this an easy job?
I notice that there are not too many fins left on mine. Don't know where they've gone.
Tubes look ok and there doesn't appear to be any leaks.
Don
Yes..
Bought a pattern one from eBay - check carefully you get the correct one.
I cannot recall exactly what I did (I was about 7 years younger than now) but I don't recall any real problems. Bleeding the system of air afterwards was fun.
If in doubt a Haynes manual helps..
Thanks for the reply.
I have a Haynes manual on its way.
Hadn't thought about having to bleed the system.
I see that there are pattern rads on eBay for about £30.00.
Don
Just wondering if overheating might be cause of my misfiring problem.
