2.2 d4d boost leak... How to check
Hi everyone
another possible problem iv noticed on my 2006 verso is a possible boost leak.
i hear a rather loud whooshing or sound like spraying an aerosol throuout the boost range when accelerating, this is my 4th turbo car and am sure it's too loud to be turbo spoil alone and most likely a boost leak.
its more obvious on the passenger side and I think low down near the bottom.
i see the turbo is mounted high up on that side, where do the pipes go or route??
i want to try the soapy water method on pipes and joins but struggling to follow the route of the boost pipes.
Can anyone help with where the boost pipes route round the engine bay??
Hi
Pipe goes on top of the gearbox hels by two bolts .it travels down to the intercooler if you look straight down by on the left side of radiator the it goes out of intercooler on the right side of rad.. then comes up to throtle....you might find a cut in one on the left side as they normally burst
