E12 1.4 D4D limp mode/engine management problem
Hey guys, I bought a 2006 1.4 D4D Corolla yesterday, found no problems with it, drove it home (120 miles or so) and it was 100%. Today though I was driving and engine management light popped up, into limp mode, needed to go into 1st gear to edge it to the side of the road. I turned it off back on , the light stayed on but I could drive it normally. I got a Snap-on computer and plugged it in, no faults showed up but the light was still on.
I actually found a post here to say
Put ignition on without starting engine remove EFI fuse under bonnet 15amp? Then replace and light goes out. Saves you having to pay garage to keep resetting it. Kev from Northumberland
I did this light went out and thought I was onto a winner, but 5 minutes later while driving happened again. I'm planning on going to Toyota in the morning in hope they can check it for me (very doubtful with Toyota here) but if anyone has some idea what it might be I'm open to suggestions.
Car has full service history, regularly serviced and 160,000 on the clock.
cheers ian
Update on the car, got to Toyota Two faults P0045 turbo boost control circuit and p1121 ac pedal position sensor open circuit
Possible wiring issue
He has never come across it might be a dirty plug or something  could be more.
Any steps on this?
