How hard is it to change the front and rear engine mounts on a Toyota corolla t sport.....anybody done this....thanx..
Sent from my HTC One M9 using Tapatalk
Bit fiddly to take out the rear, even more when putting it back in as it does hit brake pipes in the way so be gentle when wiggling it in. Fronts are easy, I found it helps to take the weight off so support the engine from below. I had lump of wood on scissor jack lifting just a wee bit.
Nice one cheers matey, gonna swap front and back to try to eliminate vibration on my t sport at high revs....
