strange vibration / rattle
fishfingers24
Hi all I am new to this forum so hope I have posted this in the right space.
I have the saloon 2015 model and I have currently done 30k in 7 months. Don't worry I'm a taxi driver so that's normal.
I have a strange noise (vibration) which sounds like it is coming from inside the dashboard  (passenger side)
The noise usually occurs when the engine is struggling slightly. An example would be going up a slight hill in high gear. I have also found the sound is more noticeable on more uneven roads but also when you pull off with a slight ***** which sounds more of a creaking sound.
I had my partner experience the problem with me when I took it for a test drive. She said she could feel the vibration from the (windscreen end of the dashboard)
I have tried many things. Looking for loose objects under the dashboard. Removing wipers etc but with no such look. However it does seem the problem is more frequent when the engine is warm.
If anyone has any idea please let me know. I have it booked in next week as the noise drives me crazy expecially when you are in it 8 hours a day.
Many thanks
