Alarm Issue When Door is Mechanically Unlocked
mafyoo123
Hi all,
just bought a 7th gen Celica (love it) but the alarm sounds when I use the key to open the door manually (using the keyhole). No problems using the fob. Alarm only sounds when I open the door.
Has anyone had the same issue/know the ways to fix it?
I'm pretty sure that's what it's supposed to do if you've locked it using the fob.  Locking with the key probably won't set the alarm, so you could unlock on that occasion without the alarm sounding.
