Hello,
My car lose power and enter in safe mode with this code P1222...
I searched on google but can not find anything that links this code on Corolla 2.0 D4D from 2001
Any idea??
P1222 = Throttle control motor circuit malfunction, and indicates a possible fault within:
*Open or short in throttle control motor circuit
*Throttle control motor
*Throttle valve
*Throttle drive gear
*Diesel throttle body
*Engine control motor
Ok, thanks...
  • 3 years later...
The same thing happened to my truck. It Lost power and entered in safe mode every time the check engine light turned on.  It turned  out to be broken ground wire. All I did to fix the problem  was replace the broken wire, deleted the error code, and it didn't return. My advice to  you is, that before you spend any money buying new expensive parts, check all the wiring connected to your throttle.
