2009 Toyota Auris Sat Nav CD
ImaFan99
HI,
Anyone here know where I can get a 2009 Auris Sat Nav CD from, apart from Toyota. Or is there a way to fix the problem I have. My Sat Nav need a cd to boot up, can't even play radio. The problem came from me replacing the Battery. I don't need to use the Sat Nav, just the radio and Cd player.
A few of options - breakers or eBay. You could also put the message on other forums (Avensis Mk2), as they may use similar CD/DVD.
I learnt something from my friend even though I did advise him, do not buy a car without the discs or memory card that should be included. He did have the discs, and when the Battery was disconnected for a clutch fix, the radio would not start without the disc inserted. Once booted and left for a day or two, he could then remove the disc. I did tell him to remove the disc before the car went in, because it could go missing (read stolen)!
Treat it as a security measure and backup. This is a warning to others.
Hope you get sorted.
