MAF/MAP Sensor - Can it be cleaned?
Mark_P
Does the iQ have a MAF Sensor, believe the Aygo's have a combined MAF/MAP sensor which might be the same for iQ if true.  Is it possible to clean the MAF/MAP sensor and where is it located?
I only ask as I've just cleaned the MAF sensor on the wife's Mazda 323f to cure a bad case of juddering in low gears and now the Mazda is running much better. I'd like to give the iQ sensors a clean if its easy to do!
Cheers,
Mark
