Brake calliper rattle
thatch
Hi guys...I have an 08 Avensis d4d with 130k miles the front brake callipers rattle a lot in rough ground. I have changed the slider pins with after market ones but only helped for a week and now it's  as bad as ever. Have greased them too and this helps for a day! Would genuine slider pins help? Or is there any other cure for this annoying problem?
there is ( quite close to spring metal) brake pad guide shaped metal inserts
they go between the cast calliper and the brake pad
bet you have one or more missing
you usually get these with new callipers and not seperate
it is an annoyance but not lethal and your best getting salvage from a breaker
stupid fitters lose them or chuck them thinking they are a nuisance
due to new brake pads being tight on fitting causing brake drag
when if you know what you are doing
remove these during a pad change
clean rust build up off cast calliper
clean these (shims/sliders)
refit with copperslip or suitable silicone grease or whatever you use
fit new pads nicely
bing bang bosh
some folk just need educated
