Engine Codes
dub_boy
This might be useful to some of you:
Toyota Engine Codes
Toyota engine codes are split into two sections, the bit before the dash, and the bit after it (eg: 2JZ-GTE).
Before the dash.
The letters signify the "family" or "series" of the engine. The numbers signify a revision of the bottom end (ie: bore, stoke, block). Higher numbers don't necessarily mean a larger block.
For example, the twin turbo engines in modern Supras are the 1JZ-GTE and 2JZ-GTE. The 1JZ is a 2.5L engine, while the 2JZ is a 3.0L. Both are twin turbo inline sixes.
The letters after the dash specify the features of the engine.
G - Wide angle Twin Cam (sportier head)
F - Narrow angle Twin Cam (economical head)
T - Turbocharged
Z - Supercharged
E - Electronic Fuel Injection
U - Emissions control (Japanese)
C - Emissions control (Californian).
Sample Engines And Their Codes
These are a few engines that can be found in our members' cars.
4A-GE: 1.6L DOHC EFI 16V inline four cylinder
4A-GE (20 Valve): 1.6L DOHC EFI 20V inline four cylinder
4A-GZE: 1.6L DOHC EFI 16V supercharged inline four cylinder
7A-FE: 1.8L DOHC EFI 16V inline four cylinder
1G-GTE: 2.0L DOHC EFI 24V intercooled twin turbo inline six cylinder
3/4K-C: 1.3L OHV Carby 8V inline four cylinder (4K block, 3K head)
5M-E: 2.8L SOHC EFI 12V inline six cylinder
7M-GTE: 3.0L DOHC EFI 24V turbocharged inline six cylinder
18R-C: 2.0L SOHC Carby 8V inline four cylinder
18R-GEU: 2.0L DOHC EFI 8V inline four cylinder
3S-GE / 3S-FE: 2.0L DOHC EFI 16V inline four cylinder
3S-GTE: 2.0L DOHC EFI 16V turbocharged inline four cylinder
2T-G: 1.6L DOHC 8V inline four cylinder
No-one knows about the H as its rarely used.
I think of it being High compression as that is the biggest difference between the 5E-FE and 5E-FHE.
A.
