Auris Hybrid - Best Spot to Tap Reverse Light Wire For Park Sensors?
Gerg
I am hoping to fit rear parking sensors to our 2013 Auris HSD hatch.
Has anyone found an easy place to connect the new wire into the existing reversing light feed?
Does the reverse light feed wire end up in the bundle on the l/h sill or r/h side sill?
Thanks in advance!
If you register with www.toyota-tech.eu you should be able to search for the installation manual for the reverse sensors (under accessories I think), which should give the info you want.
Just in case any one is interested:- The wire from the reversing light bulb holder to a 20-way plug on the l/h 'C' pillar is white with a green trace.
It leaves the 20-way plug/socket as a red wire, and then almost certainly runs to the front of the car along the l/h sill.
The wire is relatively accessible where it runs horizontally along the 'C' pillar.  There is almost no cutting of insulation to join on to it here.
