2006 (56) avensis t180 headlight problem
Tripy1664
This morning i started my car and switched on the headlights and there was a small pop sound then i noticed my lights wernt on got out n checked... Side lights on dipped beam off tried full beam working fine....went to check fuses cant find out which one is which . Checked fuses under bonnet all fine then looked at ones behing glove box all fine.. Anyone help
Ps i havent checked the bulbs yet thought it wouldnt be 2 bulbs blow at same
Could be that one bulb had already blown, and that the second decided to give up the ghost today.
I've had two headlight bulbs blow at the same time on a Renault I once owned.
SORTED YAY the wires which go on to the bulb had frayed on the short pin/wire which secures the bulb in place which shorted both bulbs but not blowing any fuses tapped up temporarily and refitted new bulbs  work ok... Going to put HID kit in next few weeks so will rewire it up then
