Need some help and advice on my 1998 RAV4
Joshb92
I've owned a 1998 RAV4 for just over a year now it's done 120,000 miles.
About 6 months into owning it 5th gear started to slip, I know this can be a common problem. Maybe more to my stupidity in knowing I was only really driving it down carriageways I was happy keeping it in 4th but recently it's starting to slip out of 4th if I'm going at low RPM just over 30MPH if I put it into 4th over 40mph it doesn't slip out or hasn't yet I've been reaching 70mph in 4th quite a lot now for about 8 months.
I absoloutely love the RAV but what I want to know is if anyone might be able to give me an idea into what the issue might be and is it worth trying to fix, or might it just be time to start looking for a new car?
Do the easy-ish stuff first
1   Check gearbox oil level and top up if required.
2  Check engine mounts are not goosed. If they are, gears can fail to engage. Change them if required.
The harder stuff is as follows
3  Selector forks are goosed. You may be able to replace them alone rather than the whole gearbox - not sure....
4  Gearbox goosed - try and obtain a reconditioned unit. Labour time will be at least a day.
