Creaking rear brake
jimtaxi
When actuating the electronic parking brake just at the end of the sequence the brake creaks to a stop. When the the brake is released it creaks immediately then unwinds normally. I have traced it to the nylon type bush where the cable goes through the lever on its way to the end with the pin is this a sign of metal fatigue or just a dry bush.
