Auris 1.4 4ZZ-FE = Corolla 1.4 4ZZ-FE?
discreet
Sorry if this is a real noob question and has been covered elsewhere, but I'm having trouble finding info on my Auris 1.4 VVTi 4ZZ-FE engine.
Is it essentially the same as the Corolla 1.4 VVTi 4ZZ-FE engine? Particularly regarding position of gearbox oil filler and drain bolts, engine oil bolt, oil filter etc etc?
Thanks very much. :)
As far as I'm aware, the 1.4 was a straight carry forward from the Corolla to the Auris. It lasted in the Auris less than 2 years before being replaced in late 2008 by the new 1.33.
Thanks very much for the reply FB, I have since done a fair amount of preventative maintenance including gearbox oil change and it does seem that a 4ZZ is a 4ZZ regardless. :) Thanks again.
