Hi Experts:
I purchased Toyota Corolla model : ZRE181L-DEXNKW (made in Turkey). During the car wash, I noticed that the material spread in different areas in the car under body looks abnormal.
I washed another 2 cars same model and I noticed that they are identical in the way the material spread. I believe the Toyota's factory must be same in spreading such material in the car under body , right ?
My questions are:
can the factory in Turkey produce a car that is different?
can this be considered as factory low quality finishing?
Can such difference affects the car's safety?
here is some pictures taken from the 3 cars under body.
the suspected car VIN/Chassis : NMTBB9JEX0R158147
Factory_Settings_Part1.pdf
factory_settings_part2.pdf
We don't have the Corolla in the UK, and the Corolla isn't sold by Toyota GB.
If you have concerns as regards your vehicle, raise them with Toyota Ireland, which is presumably the importer -  https://www.toyota.ie/models/corolla/index.json#/iframe/https%3A%2F%2Fassuredusedcars.toyota.ie%2Fforms%3Fform%3Dcontactus%26model%3Dcorolla
