Thinking of fitting a brighter bulb to the interior light of a 2016 Aygo, but fitting a bulb to this isn't covered in the full owners manual. Doesn't seem to be any obvious recess where a blade will fit. How does the lens to the interior light come off?
Dude...
There is a little notch mid way down the driver/right side, get a thin flat screwdriver and lever the light down towards you and out of the surround...
Notice my bulb? It's a nine element SMD LED, it's the mutts!!!
Its a different fitting in mine.
Ah later model, integrated bluetooth Mic!!! Jealous much...
Sorry, can't help there...
Just a new to me Aygo - (2014) thought exactly the same it need to be so much brighter!
Yep same problem for me. I must have spent at least an hour trying to figure out accessing the bulb without breaking anything. There must be somebody who has figured it out! :)
ditto any clues on how to open ?
does anyone have a diagram or schematic of the boot or wiring assembly and or parts diagram
I have taken mine out to remove the remnants of some bugs which managed to get stuck inside. It came out as whole assembly and just pulled out. I can't recall exactly where I levered the assembly but it did just remove without the removal of any screws etc. It is held it with some simple sprung clips.
Thanks, is is a wedge W5w 501 style bulb or a festoon (metal contacts at both ends)?
