Hight adjustable passenger seat?
2912pwil
You'll see I have a Icon Avensis.  The wife wants a higher passenger seat:  Anyone got any suggestions for how/where to source one that will fit the rails?  Appearance not too important as if & when we sell I'd put the original back (or is that tough with wiring etc...)
Regards & thanks in advance
Suppose the main issue would be as regards the seat mounted airbag.
Why not see whether a height adjustable sub frame is available.
if you can find a TSpirit/Excel in a scrappy/salvage yard they have powered, height adjustable passenger seats same as driver's. I suspect that the wiring harness will have existing unused connections for one.
Will probably be part or wholly leather though so you might want to swap both driver & passenger seats.
A cushion?? "Joking" heidfirst's is what I'd of went for too.
I have a T Spirit with electric leather and my passenger seat does not go up and down only forward and backwards and recline.
My Auris has a height-adjustable passengers seat, manually operated, the salesman said the Auris range all had them. My wife thought it was a good feature along with the reversing camera fitted as standard. I don't know whether the Auris seat would fit the Avensis seat base or match up with the interior but it's maybe worth bearing in mind.
a T27? Does your profile need updating as it says a 2003 T3-X?
My T27 TSpirit's passenger seat cushion goes up & down as well which is why I suggested it.
2006 ts3x t25 and mine has manual height adjustment on the passenger seat! 😌😁
