Spark plugs
toylexus
Hello all
Ive a 2 litre avensis 2004 petrol. What plugs to I need to use? Do I need the Iridium plugs?
Thanks in advance
The spark plugs will be Iridium and Denso are the best option. Denso SK20R11
http://www.denso-am.co.uk/e-catalogue/
The following eBay link shows the price you can pay in the UK per plug:-
http://www.ebay.co.uk/itm/1x-Denso-Iridium-Longlife-Spark-Plug-Part-No-SK20R11-3297-/191736982320?hash=item2ca46a2b30:g:AI4AAOSwDuJWxUi9
Depends on which 2.0 lite engine you have
1AZFE = SK20R11
1AZFSE = SK20BR11 the "S" in the engine number denotes the engine as having Toyota's D4 direct injection petrol fuel system, the engine cover will have a big D4 on it
Thanks devon aygo, d4 on the engine cover so obviously the direct injection system. Do you recommend sticking with denso? Thanks for your reply
9 hours ago, Konrad C said:
The spark plugs will be iridium and Denso are the best option. Denso SK20R11
Thanks konrad, appreciate your advice
The link Konrad gives is for SK20R11 the D4 engine requires a slightly different plug version SK20BR11 which is specific to the D4 direct injection engines. I'd definitely recommend sticking with Denso aswell
