Auris SR180 issues
Jimbo80
INTERMITANT ISSUES:
Idle fluctuations between 700 & 900 rpm sometimes results in stalling. (Happens hot or cold)
Hesitation/loss of throttle below 2000 rpm. (Pressing throttle won't raise revs but blipping throttle and depressing clutch sometimes helps)
Went into limp mode at 70 mph. Obd2 showed high common rail fuel pressure.
WORK DONE:
Replaced -
EGR / FUEL RAIL PRESSURE SENSOR / AIR & FUEL FILTERS
Cleaned -
MAF (and swapped with other) / Professional engine CARBON CLEAN (Hydrogen & Oxygen) / Injector & DPF fuel cleaners
Also drove for 120 miles to blow out soot.
Only faults flagged are EGR and high commonrail fuel pressure.
My car below (not related to carbon cleaning in progress):
Any ideas?
Many thanks
