Celica ABS light help!
Littleslick
Hello, I'm not sure if this is the right place to post but I need some help and thought I'd come to the experts! I have a Celica (2004) and have had it for 6 months. Last month the ABS light started flashing when stationary. Local garages can't find a fault but Toyota said it was a faulty ECU unit so I had this replaced with a secondhand ECU but I still have the same problem. It has now cost me around £300 and I'm no closer to it being fixed. Has anyone else had this problem or can suggest what I might try to fix it. It's an MOT failure so I don't have long to sort it out. Thanks so much for any help you can give me! Jackie
