Does anyone know if Toyota standard stereo is fitted with ISO connectors?
The model I have Toyota 58807, how do I tell if they are ISO or not?
I am trying to fit a Parrot Hands free kit and need to find out if I need to buy the additional cables if its not ISO.
Thanks.
The T25 Avensis which ran from 2003-2008 didn't have ISO connectors, if it's any help.
Not as far a I know, thats why they make adapters like these.
https://www.dynamicsounds.co.uk/ct20ty01-toyota-carina-celica-coaster-corolla-cressida-echo-wiring-harness-adaptor-iso-loom.html
They are only of use when fitting an aftermarket head unit, so think your only option is to do a cable splice, assuming you can work out which wire is which !!
Doubtful you will get a second chance if you pick the wrong wires, so triple check before doing so.
Though popular, the ScotchLoc type of connectors are considered by many to be poor, a soldered slice being better.
Edit  - if you search the whole toyota forum you might find more info on the wiring.
Found this one , though not exactly the same model as yours   - http://www.toyotaownersclub.com/forums/topic/86114-radio-connections-on-rav42/?page=1
Thanks guys, your right, not iso.
I've ordered the sot connectors, ones that allow you to tap into the existing harness.
Thanks OC for the link to that post, that was a good read.
Will update you guys once it arrives and HF kit fitted.
All done, works great, fitted professionally...by myself.
Had a telemute box and wiring harness from past, someone just cute off and left junk in there to rattle all this time, nice and tidy now.
