anyone got one?
cheers chris...
Hi there...
I'm looking at getting one of these, so I'd be interested to know the in's and out's of them too
Kev
i got a quick shift set from TRD....for my Corolla Tsport E12
and it make very fast the shift...
and very short.
also i noticed is more stiff than stock.
the install is very very easy, like 25mins to install.
how much it cost u? it's only good for drag race isnt it?
I got mine from TTE;200 euro or so;piece of cake to fix it
very short and very quiq:
hope to help you
mircea
I modified my original gear lever to a quick shift, yes iots only beneficial if you race (or you have a really large head unit and cant get your hand to it when in 1st or 3rd gear :P )
can tell you how to modify an ae92 lever for quick shift, not sure about others but they're all much of a muchness, basically you need to move the 'ball' UP[/] the shaft by 1/2" max, they're interference fit so a heavy duty press in a machine shop is recomended.
the result is a very healthy and solid movement from the lever when you shift.
