The inner door seal has worn and split  away over about a 300mm area but Mr.T wants £112 just for the part !
Have searched for any aftermarket ones but nothing at all ..?
Anyone know of an alternative supplier or an easy "patch" to the existing one ?  its worn away in line with the door handle area.
Hi M8
I have an issue with my Carina2, the rubber seal around the door latch zone & at the top of the opening, near the top of the screen.
I know superglue will bond rubber well... I'm looking to source some rubber 'pipeing/tube' to just lay into the void.. worn away.. section of sealing door rubber.
Will post if I get sorted....
2sav
On ‎10‎/‎28‎/‎2016 at 2:35 PM, oldcodger said:
I have the same problem on the drivers door inner seal, got quoted £127.50 delivered to northern Ireland from Parts-King, I decided to decline as it seems a bit extreme for a 13 year old car , especially as it is what I would describe as a comfort item .
