Auris 1.33 steering wheel switch
ZF1986
Hello,
Does anyone know if this item item will work on auris 1.33?
Thank You!
  • 4 months later...
I assume you have done some research, but just in case, here is what I have found:
http://www.toyotanation.com/forum/326-10th-gen-corolla-2nd-gen-matrix-interior-audio-forum/379436-diy-steering-wheel-control-add-ce-le-2010-corolla-updated-8-3-2011-a-7.html
The important thing is the clock spring. It needs to carry the extra cabling. Then the cabling between the clock spring and the stereo also needs to be in place.
