Avensis 2009 problem.Need help
DanielM94
Hello all.I have Toyota Avensis 2009 with automatic gearbox.It is only on 95 000 km but i have a problem.The engine is working and the shift gear is moving but when i try to move it and push the gas pedal it is not moving at all,it is not doing anything.The tachometer is moving but the car wont and stays in one place.What the problem is ?
Must be a fault with the fly by wire throttle. Does the engine rev whilst in neutral or drive? If it does not rev at all, then the throttle/accelerator control unit has a bad connection or is faulty. Check the connection first.
The following link shows the accelerator.
http://www.japan-parts.eu/toyota/eu/2009/avensis/zrt271l-awxepw/2_273560_037_410W/body/7801_accelerator-link
The engine is not making any sound at all...so i will check if the problem is in the fly by wire throttle.Thank you for now
if the tachometer is moving (& I presume that you can tell by ear that the revs actually are rising) then surely it is a transmission problem?
