Touch and go malfunction
Jtustin
Hi
I wonder if any other fellow owner has experienced this problem today whilst listening to a disc when trying  to select media or map neither would work nor would map only disc/dab or car mode no response from button or touchscreen for the  missing functions after turning the car off and back on again everything went back to normal!
could you confirm Touch & Go or Touch2 with Go? Iirc 2013 was the year when they swapped & it does make a difference for people trying to help. (fwiw I haven't seen that on my original Touch & Go).
Also probably worth mentioning which firmware/system version.
Hi it is just the 2013 standard touch and go not the touch and go 2
What software version is it running?
Select:
Setup
General
Software information
The latest software is 2.13.5 and includes fixes for freezing and unresponsive operation so speak to your dealer to arrange an update.
