EGR valve clean, 2013 2.2
enyajtrebor
Can anyone help me with the location of the EGR valve on my 2013 2.2 diesel
Fuel consumption has taken a dive - last time this happened on my T180 a clean of the EGR valve and ports made a massive difference.
I am sure that I read somewhere that you don't take this one apart like the the previous design.
Yours will have a dpf, could it be getting clogged up ?
In the words of John Cleese I would give it a dam good thrashing and see if that improves things. Uphill in 4th or 5th with some good fuel in.
Keith
Northern Lad
Thank you for your reply. I give it a thrashing once a month and avoid cheap diesel. It also gets a tin of BG244 now and again.
i did all this with my old T180 and the poxy EGR valve still blocked !!
your reply is appreciated, I will leave the valve alone.........
