im having a small whine when i accelerate. can only really hear it in 4th and 5th gear and a small bit in 3rd at time but its worse in 5th. im thinking it could be there gearbox bearings but im not sure. any recomondations? would it be worth just changing the gear box oil and see?
That's the 1st thing I would do.
What car. Is it.....
Sent from my HTC One M9 using Tapatalk
1.4 petrol 06 corola like. would you use thicker oil? i just checked the sevice history and gearbox oil change has never been done
im asuming its the gearbox
If it was the t sport I could understand as the gearboxs synchros die on the t sport , wonder if other Toyota gearbox do same ????? Mines in at mo for new synchros .....😥 I tried new gearbox oil but didn't make any difference , always worth a try pal as an easy job to-do....
ya ill give it a go just the oil. i was doig long journys daily for about 2 months started coming after that
Suggest you stick to a good quality oil of the viscosity recommended, using thicker or thinner oil more likely to give problems, partic with gear selection.
You will have to start somewhere and eliminate the obvious first, like the gear oil, which sounds like its needed anyway.
Checking the driveshaft,  hubs , brakes ,discs for noise/wear/damange would be next on my list.
ya have all that done so just gonna change the oil thanks
Funny enough my work van 14 plate transit (new shape) started the same thing Saturday. Took it to Ford today and it's the bearing in the gearbox. Covered under warranty but only just. Trouble is they want next week for about 3 days.
Sounds like yours could be the Same mate!
ya went to dealers today and they said it was the bearing. 600 fix it so not paying that ha
Same problem as me. In fact I'm waiting on the AA as we speak cos my van is stuck in 5th gear and I think the clutch bearing has come off/shattered.
I'm sure others out there will be cheaper.
My friend owns a garage in hyde manchester that specialises in Toyota's if your not to far away!
Look up "Gearbox and Transmission" specialist garages in your area, usually they  are a lot less, or take a chance on a scrappers gearbox.
Looking at your other recent posts, perhaps a complete engine / gearbox  swap might be  better option if you can find one at a decent price or simply a new car if you can find a worthwhile one at a low price ..
Low whine especially when the car slows down as you let go of the accelerator? My compressor gearbox makes a low whine also, I think they are like that, I haven't had any problems with it though.
Sam Nadeem in Birmingham does a new clutch and reconn'd gearbpx with longer 6th for not a lot of dosh..
