Cruise control wiring
123techno
Hi all,
Ive got 2006 Blade (Closest to Auris). Apparently I can add cruise control to this car quite easily, just by buying the cruise control stalk and bit of wiring.
With most of the cruise control addons to Toyotas its just a matter of adding the stalk to the steering wheel. However in some cases you need to run some wiring from the steering column to the kick panel fuse box.
I did some googling and only found instructions for a Yaris to add this extra wiring. I need help for doing this in the Blade.
The stalk has 2 wires . signal and ground. Basically I need to know where is the cruise control signal wire to the ECU. Does anyone have a wiring diagram for the Auris I could use ? Should be some wire in the passenger (RHD) side fuse box. Its impossible to find an english wiring diagram for JDM cars.
Regards,
