Auris sound system
VSD
Dear all,
I have a 3-week old Auris Icon.
Today I was fidgeting with the balance / fader options & noted that rear doors speaker output (when fader is full-rear) is quite low, compared to front.
Is this normal?
Presumably you will update your profile to show the Auris .....
Is this normal?
I think that's normal, mine does the same; I usually keep fader at R2 or R3.
There are no tweeters in the back and they get turned down as you fade towards the back so that will make a difference. It's abit clearer if you sit in the back..
