Noise when turning steering wheel while driving
mik23
Can any one help
Noise when turning steering wheel while driving  on the right side.
where / what to check.
YARIS 2005 5 speed manual.
What type of noise ?
I had similar on my Auris. Turned out to be the splash shield rubbing on the back of the disk brake. Only happened when turning left. Solved by bending it back slightly - levered away from the disk with a plastic lever.
Jez
Jez
it may be the scraping type noise ?
Yes it was a light metallic scraping. Easy to check see and fix with the wheel off.
Gents
Today again after 30 min driving when coming back home whenever I steer to right 10-15 degree or more I hear the sound from
Front right side of the car squealing.
I parked the car drove on kerb and spray transparent grease on rear side of the tyre.
Again
I drove and turn right quickly slowly all gone normal.
But I suspect its need grease Do I need to take of tyre
Can anyone advise.
