Colour spec for my Prius T3 VVT-1CVT
MikeS5762
A label containing much info is stuck to the body work behind the driver's door.
Grateful for some direction to identify on the label the paint colour spec number.
Thanks       MikeS.
The colour code is either numbers or a combination of letters and numbers. Will be either on the plate on the B pillar or a plate inside the engine compartment - the code should be after 'C/TR' (colour/trim).
