Crystal Clear Bumper Lights.
Calisto
I found some crystal clear front bumper lights on e-bay, phoned the bloke up he had loads in stock, we arranged to meet at the services on the M62 :ph34r::lol: he put them in for me and now my girl looks even hotter. :thumbsup:
did not get them for £30, but in between £30-£60 :ph34r:
I could start a group buy for these but need but would need at least 5-10 peeps.
Some clear side repeaters would finish the look perfectly, Asha! ;)
Toyota part no - T81730-02020. about £30 for the pair. they come with the orange bulbs, and will just swap out for the old orange ones....
They are slightly smaller, but as long as the cover the hole left by the old ones (which they will), you can use a bit of silicon sealer to hold them on and seal the edges.
I very nearly bought the clear indicators yesterday whilst the bloke was fitting my bumper lights. But Like you said they will need silicon. But that will be the next job what silicon do I need.??? :thumbsup:
is this for bumper lights or side repeaters?
that part number is for the side repeaters mate. :thumbsup:
bump. :lol:
bump.
Just ordinary clear silicon sealant - not the white bathroom stuff! ;)
take the old repeaters off, there's a little catch on the back of them, on the side nearest the doors. Just use a blunt knife or something to get behind the rubber, and pop them off.
Then swap the bulbs and the housing (cos the old bulb fitments will be fine), and spread some silicon on the back of them, and push them into place.
You'll probably have to move them about a little to get them to cover the old hole, which is slightly bigger.
Once you're happy with their placement, use a bit more silicon (on your finger is best, you can work it in behind the seal that way!) to seal around the rubber seal.
Easy. :P
Edit - And here's how they look once they are on.. :)
its also a good idea when popping out your old side repeaters to have a spot of masking tape around the edges so that you dont scratch your paint by being a little over eager.....easily done i can tell you!! :ph34r:
