brake judder
salohcin95
hi
this is my first post! i bought my 1999 rav4 about a month ago it has mint body work and every thing under the bonnet seemed fine too, but over the last few weeks it has been making a really bad judder under braking! i can feel it through the pedal and steering collum when this happens the brake hardly work? its very intermediate ive changed discs and pads but its still happening if you guys could help me identify the issue it would be amazing
thanks nick
Possibilities include
Brake piston sticking inside caliper. Free it off or replace caliper - with piston installed. Your disc may become hot - even when not braking.
Brake system requires a bleed
Master or slave cylinder goosed
Brake servo leaking or goosed.
Sticking piston or pistons would be a distinct possibility. If it's been happening for a while check for excessive wear on one pad, exercise both pistons and clean, regrease the pads before fitting and be careful to change pads before the worn one connects metal to metal, or even better change immediately. Were any of the pads you removed previously worn more than the others?
