2006 toyota noah noise in engine and stutters at low speed
jerbro
Just bought a 2006 toyota noah. It is making the attached noise when driving or even when I just start it. I have noticed that the engine is running a bit hot, so I may need to get the raidiator serviced. The noise is mainly heard when inside the vehicle. When I open the hood the noise of the engine masks this noise.
What could that noise be?
I also notice when I am driving at really low speeds, hardly giving it gas, it bucks/stutters a few times
Please let me know what you think
20161210_001 [High quality].mp3
20161213_001 [High quality].mp3
"Noises" are often hard to define or locate.
There are many possibilities as to hot running and rough running...why not get a code read done...guessing can be expensive.!
Coolant level ok.?...no leaks.?...thermostat ok.?...rad cap ok.?....rough running maybe bad plug.?...bad coil pack.?...MAF.? (assuming petrol.?)
Process of elimination...Hence the code read.,:wink:..it may just point you in the right direction.
