Best turbo on toyota 1nt ?
Toyota malta
Hi i fitted a toyota engine 1nt  on a suzuki vitara it is running on a stock small turbo. It has alot off lag and smokes black will a bigger turbo helps i have heard that a ct12 will produce less lag than the small turbo i am running and the turbo i am running now has a little shaft play and is boosting 10psi thanks help  will be appreciated  🙋
