Toyota Yaris Tsport 2001 uk
Dimples2198
Hi i have recently bought I Toyota yaris t sport on a 2001 reg it is a Japanese import it has been stationary for a year and a half and I have wanted to get it back on the road as a little project because its already had quite a lot of work done to it, so it has been in the garage for quite some time I have had the clutch changed still looking for a gear linkage and other t sports have different gear linkages as I went to test the car it knocked out on me whilst I was doing about 30 mph and all the lights turned off I tried jumping it because I was in speed and that didn't work, so after pushing it to a side I bought a jump pack and attached it and it started but as soon as I removed the black cable the car would turn off after a few attempts smoke started rising from the engine??? so I was wondering what the issue is?? as I have never experienced this before p.s. the mechanic arranged the wiring under the bonnet if ts due to that thanks for your help looking forward for some advice
sound like an earth issue check all earth connection . try a jump lead from the Battery to the top strut bolt or engine see if works
