Is this turbo on way out? 2.2 dcat
Avensis 2.2 nj
Tjek all the pippe work for the intercooler, air filter, intake ect.
If it is a smal crack you can not always feel the loose of power.
Also tjek the intake blades on the turbo. Damage to the blades can give that noise.
Sometimes it can be unbalance because oil steam burns on to the intake blades, can somtimes be removed whit an intake spray cleaner.
Do the car smoke black/white/gray under full load?
The list of causes/tjeck points can be long.
/HartmannX
Hi thanks for reply. There's no smoke no loss of power just that whining! Do you think turbo cleaners such as forte turbo cleaner would help?
I do not hnow the brand. It is the intake side that is important to clean. If you want to try it.
It is also worth a try to make a engine flush (oil system clean) if there are burned oil to the axel. You cant check the axel without removing the turbo.
Hey guys .....car is still running ok after I inserted turbo cleaner but since I put it in there's a occasional cloud of smoke this has only happened twice since I last posted which was 5 days ago. Is this smoke because of the turbo cleaner I inserted? The fuel mixed with the turbo cleaner is nearly finished now so this weekend il put a full tank and start afresh hopefully no more smokes but has any had experiences with these turbo cleaners or additives?
what colour of smoke? If yours is a t180 it could be the DPF regenerating (this tends to be white).
Thanks for reply to be honest it was night time, but I would say white and it was a lot of smoke. The car still drove ok. So I just took it for a quick drive on motor way for 10 mins and there was no smoke at all then.
And yes mine is the t180
  • Topics
  • Our picks
        • Like
        • Thanks
        • Like
