I want to take a 1993-1997 Toyota Corolla 1.8l Manual and switch the engine to a 3sgte 5speed with a mr2 tranny, the engine mounts should swap like a st to gt celica, but what I need to know is if the mr2 tranny will fit or if I'll need custom tranny mounts and if I'm going to need to relocate stuff in the engine bay. Also will the drive shaft be fine or will it need have custom work done as well. Also for wiring an I going to need a new cluster or will the corollas cluster plug and play? Will i need to change axels and wheel size?
