I wanted to remove my headlights to reseal them as have got some condensation building up inside it.
Any idea what the easiest way is to get to these as ive been looking all over and for the life of me can't find anything. Thanks
There are 2 bolts under the bonnet and 1 inside the wing, if you remove the arch liner you can get at that 3rd bolt.
Thank you
Do you recommend jacking car up abit or not? And would i have to remove the tyre
4 hours ago, sohail-94 said:
Thank you
I had to remove the headlight to replace a bulb......j found that out the hard way haha.
You don't have to jack up the car or remove the tyre, just pop out some of the plastic screws that hold the arch liner in place and pull it back just enough to stick your arm in with a socket, that's what I did.
Thanks ill let you know how i get on
got my bulbs today
bought
phillips diamond vision H7
2 White LEDS
and two chrome indicator bulbs as I thought might aswell change the lot
got my bulbs today
bought
2 White LEDS
Yes I would advise changing the bulbs while you have the headlight out, make sure you change both sides and don't touch the glass bit of the bulbs as this can cause them to fail prematurely.
