Door trim noise
Lyono
I have just sold my T25 and now have a T27 1.8 CVT registered in June 2014. It's come with a bit of an annoying squeak and rattle from the rear driver's side door trim when I hit one of London's many bumps and potholes. If I lean on the trim when stationary it flexes and the same light squeak can be heard. Has anyone else had this problem? Is the trim easily removed and refitted if I tried some lubricant and foam rubber? Or should I take it to the dealer?
Let the dealer sort it under warranty
