Toyota avensis power issue
paddyk83
2001 d4d toyota avensis non air con.
Loss of power , car stutters and cuts out
When heater is turned on it can happen .stops when switched off again.
Also happens when rear window heater is switched on.
Also happens when auto window switch is used. Example when i click switch to automaticly close the window, once the window closes the car stutters .  So if window was closed and i pressed the switch to close the window the car would stutter
So basicaly i dont know whats causing this electrical issue or where to start
Any help /advice appreciated.
Moved to the Avensis club
