Got all gears car wont drive...
Tomas Bangor
Similar problem with my Avensis 2008 d4d manual. Went to pull away and Lost drive. Got towed home, I can put into any gear engine running  with clutch pedal up and no crunching. Slave cylinder on box is moving no fluid leaking. Jacked front of car up and thinking wheels would spin with normal friction within the gearbox but stayed still. Thrust bearing can be heard slightly when clutch pedal is press down. Could dmf have slit consequently stopping the drive to the clutch.
