Change interior bulb
Nicktooley
As a qualified clumsy oaf, can anyone tell me how to remove the plastic dome covering the interior bulb on a Mk1 Yaris please?
Welcome
Take a small screwdriver. Go to one of the shorter ends of the  cover. Gently insert blade into gap between cover and base. Gently twist or pull down.
Thanks madasafish, I bet I can crack the cover!!
So I got the cover off but what kind of bulb is that, certainly not what I expected.
 a pic would have helped but I suspect that it will be a festoon bulb?
Agreed, usually festoon. Check the overall length and wattage when buying a new one.
Jez
