Rear light cluster
Swerve74
Anybody replaced a rear light cluster on an auris estate 2013. Manual says remove 2 bolt come screws and it just pulls away. Tried that and it seems stuck solid. Don't want to pull too hard and smash it. Thanks.
Have you tried lubricating the seals of the cluster with silicone spray (not dewaterising fluid (WD40, etc))?
I'll give it a try. Can you please advise if there just held in by the two screws and a grommet .
