Rear window
Gladys
Just wondered if anyone else has this problem  I got my Yaris in Oct (ex demonstration car). On 3 occasions after parking my car at work, getting back in the car front and rear windows have been steamed up  Putting heater on clears the front but the rear one doesn't clear, so I have to wipe it with a cloth  I haven't had this problem before on other cars -  any ideas?
Is your heating and ventilation system set on recirculation?
Most problems like this occur because the system is set to re-circ as above, set it to fresh and have the blower on at least 1 blow, it should keep clear then
could you have a water leak somewhere maybe check the carpets
