Hi I'm currently doing an engine conversion on my toyota corolla g6r which has a 4a-fe and 6 speed gearbox. I bought a celica st202 gt with 3sge engine in 5 speed gearbox. I have stripped down both cars and wanted abit of advice on this. Has anyone done this conversion before? What driveshafts shall I use as I presume ill need to use the 5 speed gearbox but the driveshats are slightly longer then the ones of the corolla although the splines do fit into the corolla hub. Any advice would be much appreciated
Moved to the Corolla club.
