Hi I'm currently doing an engine conversion on my toyota corolla g6r which has a 4a-fe and 6 speed gearbox. I bought a celica st202 gt with 3sge engine in 5 speed gearbox. I have stripped down both cars and wanted abit of advice on this. Has anyone done this conversion before? What driveshafts shall I use as I presume ill need to use the 5 speed gearbox but the driveshats are slightly longer then the ones of the corolla although the splines do fit into the corolla hub. Any advice would be much appreciated
